WHYNTER FM-951GW 95 QT PORTABLE WHEELED FREEZER WITH DOOR ALERT AND 12V OPTIO GRAY
Featuring a space-saving upright design that fits almost anywhere the whynter 95 Quart Portable Fridge / Freezer is a cost-effective and mobile solution for your merchandizing and critical freezing requirements. Designed for portable use and easy access you can conveniently keep food and beverage products chilled or frozen with this multipurpose freezer.
With its useful reach-in design stored foods are easy to find once it is time to defrost and prep. The Whynter has a spacious interior that includes a shelf basket for easy organization.
Features- Operates as a refrigerator or freezer
- Compressor cooling system
- Fast freeze mode rapidly cools to -6°F
- LED temperature display
- Open-door warning system
- Power low indicator
- Insulated lid and walls
- One removable wire basket
- Interior lights
- Side handles for easy mobility
- Functions even when tilted 30°
- Tough and solid outer casing
- Optional wheel casters for mobility two of which lock for secure stationary use
- 8 AC power cord and 5 DC power cord are included
Specifications- Color: Gray
- Wattage: 70W
- Voltage: 12V
- Adjustable temperature range: -6°F to 50°F
- Dimension: 27.5" H x 18" W x 11.25" L
- Weight: 62 lbs
Price: 1038.70
