DOMETIC D7E-DM2652RB 6 CU. FT. AMERICANA DOUBLE DOOR RV REFRIGERATOR - 2-WAY
The Americana DM2652 is at the head of the Dometic double door family of refrigerators. Solid steel frame construction improved electronic controls. Eye-level electronic controls automatically adjust the temperature inside to maintain consistent cooling regardless of the temperature outside. Adjustable shelves and door bins large bottle storage and dual crispers extend the flexibility of every Americana refrigerator.
Features- Versatile racking system 3 position freezer shelf
- Removable door bins 2-liter and 1/2 gallon door storage
- One gallon container shelf storage Shelf and juice rack on freezer door
- Two crispers 2-way operation
- Eye-level automatic electronic controls Doors open 180 degrees
- Positive door lock handles Black frame Accepts 2 insert panels
Specifications
Price: 2091.38
